Just had my engine changed on legacy 2010 and since i have no more lights, low beam high beam tail light illumination lights dash lights dome light dash clock.the only working lights are brake lights and flashers. I've checked the fuses and the relays all work fine. Any ideas?
If you have verified that power is getting to the proper fuses for the lights then check the ground connection going to the light switch. The switch uses a ground connection to turn on the lights so make sure that is making good connection to the switch.
