DaveT Posted June 25, 2016 Share Posted June 25, 2016 (edited) Is it just mine, or are they all nearly worthless unless you park under the transmitting tower?The stock radios in my 25 year old loyales were better. I recently upgraded them with Nakamichi radios, so I guess I'm going shopping again. Edited June 26, 2016 by DaveT Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 25, 2016 Share Posted June 25, 2016 (edited) I've heard similar complaints about reception with the newer radios. They have antennas that arent large enough to properly recieve the signal, so they use signal boosters to amplify the signal that goes to the head unit. Problem is, the boosters just amplify everything, including white noise and interference. Best thing you can do is install a proper antenna, but that requires cutting a hole in the body. Edited June 25, 2016 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
DaveT Posted June 26, 2016 Author Share Posted June 26, 2016 Ah, I'll look at that first. I can test with a loose antenna first. Quote Link to comment Share on other sites More sharing options...
