lrgvanman Posted June 25, 2016 Share Posted June 25, 2016 Anyone know where to find one of these? It is a Disk Brake Tool for twisting while turning to compress the piston. Thanks from Larry G. Quote Link to comment Share on other sites More sharing options...
987687 Posted June 26, 2016 Share Posted June 26, 2016 I just use a pair of pliers or vise grips or something. If the piston is really tight/stuck you have other problems. Undo the bleeder screw so you're just pushing fluid out the caliper, not back into the system. Should make things easier. 2 Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted June 26, 2016 Share Posted June 26, 2016 (edited) I just use a grinder wrench that has 2 pins. It works pretty good considering you don't have to change brakes very often. If i want to get fancy i could cut off the head and weld a socket to it to make it go faster with a ratchet. At harbor freight they have a little cube that does the same thing for a 3/8 ratchet not sure if it will work on these or not but they're less than $10. Edited June 26, 2016 by turbosubarubrat 1 Quote Link to comment Share on other sites More sharing options...
Dee2 Posted June 26, 2016 Share Posted June 26, 2016 I used the cube tool when I was working on my brakes. It worked well. I tried to use pliers but didn't have much success. I found the cube at NAPA. 1 Quote Link to comment Share on other sites More sharing options...
lrgvanman Posted June 27, 2016 Author Share Posted June 27, 2016 I recently bought a cube from Knechts Auto Parts but I haven't tried it yet. I have used those in the past. Then there was the elongated version that had the two pokies (spanner) on one end and a hex the other end, difficult to handle while slipping off frequently. Thanks all from Larry G. Quote Link to comment Share on other sites More sharing options...
MR_Loyale Posted June 28, 2016 Share Posted June 28, 2016 I got one at autozone. Quote Link to comment Share on other sites More sharing options...
superooo Posted June 28, 2016 Share Posted June 28, 2016 Weld some needlenose! Just kidding Quote Link to comment Share on other sites More sharing options...
