steve56 Posted June 27, 2016 Share Posted June 27, 2016 Buying a 2005 Legacy CV boot kit to replace the ripped inner boot.Whats the proper tool and proceedure for tightening new the boot clamps? Link to comment Share on other sites More sharing options...
987687 Posted June 27, 2016 Share Posted June 27, 2016 If you don't have the proper tool to get the metal band clamps tight, it's really hard to get enough tension on them. I just use a big beefy zip tie to hold the boots on. 1 Link to comment Share on other sites More sharing options...
DaveT Posted June 27, 2016 Share Posted June 27, 2016 There are a couple of different tools for different types of bands. A good parts shop should have them, just bring a band. Link to comment Share on other sites More sharing options...
lmdew Posted June 27, 2016 Share Posted June 27, 2016 For the bands with the little tooth hooks a tile nipper works OK For the bands that slip under the ring a vise grips and screwdriver used a a pry bar against the vise grips and ring works OK The correct tools are best. Sometimes I end up using aviation safety wire and just putting several wraps around. this works well also. 1 Link to comment Share on other sites More sharing options...
steve56 Posted June 27, 2016 Author Share Posted June 27, 2016 On 6/27/2016 at 10:39 AM, 987687 said: If you don't have the proper tool to get the metal band clamps tight, it's really hard to get enough tension on them. I just use a big beefy zip tie to hold the boots on. Is a heavy duty zip tie a permanent fix? It sure would be easier than the metal band and neede tool. Link to comment Share on other sites More sharing options...
brus brother Posted June 27, 2016 Share Posted June 27, 2016 this guy does the boot (inner) without removing the axle... least is best? Link to comment Share on other sites More sharing options...
987687 Posted June 27, 2016 Share Posted June 27, 2016 On 6/27/2016 at 12:15 PM, lmdew said: For the bands with the little tooth hooks a tile nipper works OK For the bands that slip under the ring a vise grips and screwdriver used a a pry bar against the vise grips and ring works OK The correct tools are best. Sometimes I end up using aviation safety wire and just putting several wraps around. this works well also. Yea, I've used 0.035" aviation lockwire as well. I'm always afraid it'll bite into the boot, though. Link to comment Share on other sites More sharing options...
brus brother Posted June 28, 2016 Share Posted June 28, 2016 in video above guy reused the existing clamps. they are already bent at exact mark. Link to comment Share on other sites More sharing options...
steve56 Posted June 28, 2016 Author Share Posted June 28, 2016 On 6/28/2016 at 12:02 AM, brus brother said: in video above guy reused the existing clamps. they are already bent at exact mark. Yes, I saw that video. Unfortunately my clamps got too bent up to reuse. Great video though. Alot of good info. for someone like me that is doing CV work for the first time. Link to comment Share on other sites More sharing options...
forester2002s Posted June 28, 2016 Share Posted June 28, 2016 I watched the video. I recommend cleaning the old grease off of the CV rollers and the inside of the cup, before adding the new grease. I was surprised that this wasn't done in the video. Link to comment Share on other sites More sharing options...
lmdew Posted June 28, 2016 Share Posted June 28, 2016 Both style tools under $25. https://www.amazon.com/Qbace-Joint-Clamps-Pliers-Banding/dp/B015IH45ZK/ref=sr_1_3?s=automotive&ie=UTF8&qid=1467111923&sr=1-3&keywords=cv+joint+clamp Link to comment Share on other sites More sharing options...
steve56 Posted June 30, 2016 Author Share Posted June 30, 2016 On 6/28/2016 at 6:29 AM, forester2002s said: I watched the video. I recommend cleaning the old grease off of the CV rollers and the inside of the cup, before adding the new grease. I was surprised that this wasn't done in the video. Yes, he should have done that. Good point. Link to comment Share on other sites More sharing options...
brus brother Posted July 1, 2016 Share Posted July 1, 2016 On 6/30/2016 at 10:11 PM, steve56 said: Yes, he should have done that. Good point. Agreed, Would brake cleaning spray be a good solvent to clean in place? Link to comment Share on other sites More sharing options...
steve56 Posted July 1, 2016 Author Share Posted July 1, 2016 On 7/1/2016 at 9:01 AM, brus brother said: Agreed, Would brake cleaning spray be a good solvent to clean in place? Just received the Beck/Arnley boot clamp kit. The instructions are:always thorougly clean out the CV joint before repacking with grease. Clean off excess gresse with rag then remove the remainder with warm soapy water. Dry thoroughly. Do not clean with any parts cleaner or petroleum based product. These will leave a deposit incompatible with the new supplied litium based grease. 1 Link to comment Share on other sites More sharing options...
