Just got a Rx need more info
Hey just pick up this it needs a transmission which from what I read the full time locking diff only came in the Rx and the Xt6 so if I wanted the same gear ratio of have to get a trans out of one of them? Or are there others I only payed $250 for it and drove it home diff bearings are making a lot of noise though ???? And this pic doesn't show the body damage on the other side
Edited by SockRx
The transmission that is in that is unique to the RXs. Full-time 4WD with locking center and low range.
The XT6s had full-time 4WD, but were a 3.9 ratio, so you'd have to swap the rear diff. And they don't have low range.
The turbo EA82s from '87-'90 had a transmission that's virtually identical to the RX trans, except without the low range.
Show more pics. I have a couple different transmissions you could swap in. I have a 3.7 d/r 4wd, 3.7 awd with diff lock, and a rx d/r awd with diff lock. I need to play with the rx transmission some since i just picked it up and it acts like its locking up when you turn the input shaft even in neutral. As in locking up i mean you can't turn the input shaft all the way be cause it hits something solid.  I'll steam clean it and let you know.
Edited by turbosubarubrat
nice find. was that the one that was on the coast? I got an xt6 parts car that still has the tranny and matching diff in it if your decide to go that route. Although I can't verify their condition I'd sell em for a cheap price that reflects that.
No not in the coast where are ya located and how much?
  On 7/4/2016 at 12:36 AM, SockRx said:
And what will I be losing?
That one is a 85-86 3.7 dual range 4wd. You loose it being all wheel drive and having a center diff to lock. Same gear ratio so no need to change the rear diff. I have the same one that i would sell for less that has 158 thousand miles on it
So what's up with that Rx trans? and how much for the awd with diff lock?
A key way came out of the transmission not sure where it came off though. It started turning all the way over once i put a clutch disk on it and it spit the key way out. I want $150 for the awd with diff lock and $250 for that d/r 4wd. I'll probably keep the rx trans since i have another one and i will eventually probably end up using it to build a custom transmission.
Okay where are you located I'm in se Portland
