Aussiecanyoncarver Posted July 8, 2016 Share Posted July 8, 2016 Hi, I know this question has been asked a lot on this forum however I aim to do as much research as possible into everything I do so I get it right the first time. I am on a fairly tight budget and would like to know a few things. 1. Will I be able to use the ej18 intake runners on the ej22 P2 block to get it to work 2. Will I be able to use the ej18 flywheel and clutch on the ej22 for the time being 3. Will the transmissions bolt up or will I need to install a different transmission 4 can I just get rid of the knock sensor and it (ej22) run fine Kind regards~Abid Link to comment Share on other sites More sharing options...
matt167 Posted July 8, 2016 Share Posted July 8, 2016 1. No. Bolt pattern is different. You can use EJ18 heads and intake tho. 2. yes 3. yes. 4. yes 1 Link to comment Share on other sites More sharing options...
Aussiecanyoncarver Posted July 8, 2016 Author Share Posted July 8, 2016 (edited) 1. No. Bolt pattern is different. You can use EJ18 heads and intake tho. 2. yes 3. yes. 4. yes Ok thank you buddy, so I will just be able to bolt up the transmission up? Edited July 8, 2016 by Aussiecanyoncarver Link to comment Share on other sites More sharing options...
