winginit Posted July 8, 2016 Share Posted July 8, 2016 116k miles just replaced head gaskets, i bought the car for $350 it looks great. i noticed the cruze does not work, i assume it was like that before i bought her. What are common problems and fixes i could start looking onto ? Thanks Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 8, 2016 Share Posted July 8, 2016 Does the button light up when pressed? If so, I'd check underhand to make sure the vacuum line from the intake to the cruise unit is hooked up. If it's a manual transmission car, the pedal stopper on the clutch pedal could be broken making the system think you have the clutch pushed in. Link to comment Share on other sites More sharing options...
winginit Posted July 9, 2016 Author Share Posted July 9, 2016 (edited) On 7/8/2016 at 7:22 PM, Caboobaroo said: Does the button light up when pressed? If so, I'd check underhand to make sure the vacuum line from the intake to the cruise unit is hooked up. If it's a manual transmission car, the pedal stopper on the clutch pedal could be broken making the system think you have the clutch push the car is a Automatic. yes the light illuminates on the switch, what does the cruze unit look like and where is it ? i will check the vacuum when i find the cruze box. thanks Edited July 9, 2016 by winginit Link to comment Share on other sites More sharing options...
jreb10 Posted July 9, 2016 Share Posted July 9, 2016 On 7/8/2016 at 7:22 PM, Caboobaroo said: Does the button light up when pressed? If so, I'd check underhand to make sure the vacuum line from the intake to the cruise unit is hooked up. If it's a manual transmission car, the pedal stopper on the clutch pedal could be broken making the system think you have the clutch pushed in. Ditto for the brake pedal. There will be a switch somewhere such that the cruise control disengages when the brake pedal is pushed. The switch may be mis-adjusted or broken. Check these type of things first as they are easier than digging into the guts of the system. Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 9, 2016 Share Posted July 9, 2016 Sorry, the vacuum canister is under hood, next to the right strut tower. It should have a small vacuum line running to it. Link to comment Share on other sites More sharing options...
winginit Posted July 10, 2016 Author Share Posted July 10, 2016 On 7/9/2016 at 1:21 AM, jreb10 said: Ditto for the brake pedal. There will be a switch somewhere such that the cruise control disengages when the brake pedal is pushed. The switch may be mis-adjusted or broken. Check these type of things first as they are easier than digging into the guts of the system. Where is the switch from the brake pedal ? Link to comment Share on other sites More sharing options...
winginit Posted July 10, 2016 Author Share Posted July 10, 2016 Thanks, Men i will check this stuff out and get back to you! Link to comment Share on other sites More sharing options...
whynot Posted July 10, 2016 Share Posted July 10, 2016 I have the same problem. So I will follow this. I can hear my "box" set when using the set lever, So I think the brake switch is ok on mine. But it will not control speed. Can I pull vac on the actuator with a brake bleeding kit and should the cable move? Do not mean to hijack, just the same issue here. Link to comment Share on other sites More sharing options...
