bstone Posted July 11, 2016 Share Posted July 11, 2016 My windows fog like mad. I can turn on the defroster but it doesn't always help. I wiped down the windshield with 91% isopropyl alcohol and then I tried RainX anti-fog but it seems to make things worse. I also tried an application of toothpaste (just paste, not the gel) and that doesn't seemed to have helped either. I'm about to buy my first ever can of shaving cream and try that but people might think that's crazy because I have a beard and have never shaved! Thoughts? Suggestions? Link to comment Share on other sites More sharing options...
john in KY Posted July 11, 2016 Share Posted July 11, 2016 The heater core has a leak. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 11, 2016 Share Posted July 11, 2016 maybe condensation drain is clogged? Link to comment Share on other sites More sharing options...
bstone Posted July 11, 2016 Author Share Posted July 11, 2016 On 7/11/2016 at 3:17 AM, john in KY said: The heater core has a leak. Can you elaborate on that? Link to comment Share on other sites More sharing options...
bstone Posted July 11, 2016 Author Share Posted July 11, 2016 On 7/11/2016 at 3:45 AM, 1 Lucky Texan said: maybe condensation drain is clogged? Where can I find the condensation drain? Link to comment Share on other sites More sharing options...
john in KY Posted July 11, 2016 Share Posted July 11, 2016 Run the AC for a few minutes and you will see a puddle of water form under the car in front of the passenger seat well. Or just look under the car, right side, for a dangling hose under the firewall. Use compressed air to clear it. The heater core is inside a sealed box. If it springs a leak, coolant begins to collect inside the box. Link to comment Share on other sites More sharing options...
montana tom Posted July 11, 2016 Share Posted July 11, 2016 Do you smell anti freeze ? If your heater core is leaking enough to fog the windows then you WILL smell antifreeze . No smell then look for a/c drip. 2 Link to comment Share on other sites More sharing options...
vtwinjunkie Posted July 11, 2016 Share Posted July 11, 2016 Do you vape? In all seriousness, My house mate vaped in his car and could not figure out how to get the film off...and it cause a ridiculous amount of fog on windows when he used his heat or ac. Link to comment Share on other sites More sharing options...
bratman2 Posted July 11, 2016 Share Posted July 11, 2016 Windshield gasket leak? Might be allowing rain water to seep under your floor mats. Check for any dampness. Link to comment Share on other sites More sharing options...
bstone Posted July 11, 2016 Author Share Posted July 11, 2016 On 7/11/2016 at 10:34 AM, john in KY said: Run the AC for a few minutes and you will see a puddle of water form under the car in front of the passenger seat well. Or just look under the car, right side, for a dangling hose under the firewall. Use compressed air to clear it. The heater core is inside a sealed box. If it springs a leak, coolant begins to collect inside the box. Definitely no water puddles in the car. I'll check under the card for the tube. Link to comment Share on other sites More sharing options...
bstone Posted July 11, 2016 Author Share Posted July 11, 2016 On 7/11/2016 at 12:44 PM, vtwinjunkie said: Do you vape? In all seriousness, My house mate vaped in his car and could not figure out how to get the film off...and it cause a ridiculous amount of fog on windows when he used his heat or ac. Nope. I was born with a healthy set of lungs and will keep it that way! LOL! 1 Link to comment Share on other sites More sharing options...
vtwinjunkie Posted July 11, 2016 Share Posted July 11, 2016 Good, haha I cant stand it either. Link to comment Share on other sites More sharing options...
bstone Posted July 12, 2016 Author Share Posted July 12, 2016 On 7/11/2016 at 11:59 AM, montana tom said: Do you smell anti freeze ? If your heater core is leaking enough to fog the windows then you WILL smell antifreeze . No smell then look for a/c drip. No coolant smell at all. Link to comment Share on other sites More sharing options...
bstone Posted July 12, 2016 Author Share Posted July 12, 2016 On 7/11/2016 at 2:12 PM, bratman2 said: Windshield gasket leak? Might be allowing rain water to seep under your floor mats. Check for any dampness. No water on the floor. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 12, 2016 Share Posted July 12, 2016 I don't recall what car you have, but if you google subaru a/c condensation drain and click images - probably get a good idea of wher to look for a clog. Link to comment Share on other sites More sharing options...
bstone Posted July 12, 2016 Author Share Posted July 12, 2016 On 7/12/2016 at 3:42 AM, 1 Lucky Texan said: I don't recall what car you have, but if you google subaru a/c condensation drain and click images - probably get a good idea of wher to look for a clog. 97 Outback Wagon Link to comment Share on other sites More sharing options...
