Fatenarr Posted July 14, 2016 Share Posted July 14, 2016 I have a 96 Subaru Legacy L ej22e and I'm looking for a link or the actual part number for an oem clutch for this vehicle? All I seem to come across online is exedy which is what I just installed and has a bad chatter at take off. Link to comment Share on other sites More sharing options...
lmdew Posted July 14, 2016 Share Posted July 14, 2016 Did you surface the flywheel? New pressure plate and through out bearing? Exedy clutches have been good to me over the years. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 14, 2016 Share Posted July 14, 2016 You won't find a kit for an OEM clutch. Subaru only sells the parts individually. Clutch disc, pressure plate, release bearing, and pilot bearing. Check subarupartsforyou.com. I think they package them all together. Good prices too. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted July 15, 2016 Share Posted July 15, 2016 Have you driven it much? Log some miles before worrying about chatter. If the problem persists, as mentioned, look to the flywheel or TOB as more likely causes. Exedy are the standard best replacements. Link to comment Share on other sites More sharing options...
