stickedy Posted July 30, 2016 Share Posted July 30, 2016 Hello! I have a problem with my IACV / unsteady idling after swapping my engine (from MT car to AT car), see http://www.ultimatesubaru.org/forum/topic/159399-swapping-engine-from-manual-transmission-to-automatic-transmission/ Everything is fine so far, but the engine is idling bad, alternating between about 400 and 1.400 rpm constantly. Sometimes, however, it works fine... The ECU throws me the error code 35 for the IACV. I already swapped over the IACV from the "AT" engine in an try to correct the problem, but it had the same part number and it changed nothing. I was searching the FSMs for any hint how and where to find the issue. But I didn't find any difference between AT and MT except that there should be some voltage with AT when testing it. However, I can't find any difference in the wiring diagrams. I also changed the spark plugs and the ignition wires just in case and to be sure it's not somehow related. Please, do you have an idea what this problem is caused by? I'm a bit stuck with this problem... Thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 31, 2016 Share Posted July 31, 2016 If it has a 4 wire TPS the idle switch in the TPS may not be closing. Make sure the throttle body bore and throttle plate are clean. You can use an ohmmeter to adjust the TPS if needed. Which intake manifold did you use? Link to comment Share on other sites More sharing options...
mikaleda Posted August 1, 2016 Share Posted August 1, 2016 Did you use the intake off the MT car? When swapping engines its usually best to keep the matching intake to your car since there are a lot of subtle differences through the years of Subaru's. Was the mt car a 90 by aany chance? The 90 MTS use a different IACV Link to comment Share on other sites More sharing options...
