bendecker Posted August 1, 2016 Share Posted August 1, 2016 (edited) Hi Suba-Gurus -- I have a new-to-me 1995 silver Legacy with a mere 115k miles on it. Boots on both sides are shot. Car says ABS on the back, I can see what I believe is an ABS sensor that would sense the ring on the outer part of the shaft. Yet, no ABS ring like I've seen in various pics of new shafts. The shaft is clearly labeled as re-manufactured. So, what to do? So, a couple of noob ABS questions : 1. Should it have an ABS ring? My assumption is yes if you want the ASB to work. 2. Where to get the proper shaft if it needs one. Rock Auto and various other sources have them labeled as "No ABS Ring", etc. OEM from a pick and pull is not an option in our area. EDIT: Just answered my own question when I pulled off the brake rotor. The ABS sensor ring is mounted behind the rotor. So, please disregard the above. Edited August 1, 2016 by bendecker Link to comment Share on other sites More sharing options...
bendecker Posted August 1, 2016 Author Share Posted August 1, 2016 (edited) Next.... turn the rotors, reboot the shaft and put it shaft back in, replace the brake rubbers with OEM. Repeat on other side. Love this board. Sorry about the dumb question :-) Edited August 1, 2016 by bendecker Link to comment Share on other sites More sharing options...
Numbchux Posted August 1, 2016 Share Posted August 1, 2016 It bolts to the back side of the hub on those, not on the CV. 27550A in this diagram 1 Link to comment Share on other sites More sharing options...
