Diagnosing differential noise 2003 LL Bean
Hi, I'm new to this particular forum. I've recently replaced my transmission fluid and differential fluid, as well as put on a newer complete drive shaft on my 03 LL Bean Outback, but I can't seem to shake this noise. I'll leave a YouTube link at the bottom for anyone who's got a few to take a listen, sorry for all of my talking in advance.
I tend to strictly only hear the noise on acceleration after I reach about 25mph in several gears and speeds, and the transmission shifts very good. I've tried a heavier synthetic Luca oil in the front diff, but no change. There is no play in the axels where they connect to the diff. I get a little vibration, and I mean only a little, on the automatic shifter.
It seems like the noise comes from the tail section of the transmission, but with the diff and trans being so close together I can't be sure what causes the noise. So if there is a Subaru doc out there, tell me please, how long does she have? I always appreciate help, but if you want to reply to this, please read it all before you take a stab at it. Thanks.
https://youtu.be/9-GWX19X9_E
Edited by Lverano
  • Like 1
Welcome from Subaruoutback land.
Change fluids and look for debris.
People run fluid through cloth filters like cheese cloth maybe. See what comes out.
Noise on acceleration is usually front diff but that's a forward noise? You say it's coming from rearward?
Sit in the passengers seat and rear seat and have a listen. Then what?
Edited by grossgary
  • Like 2
I changed the front differential two times.  The front diff had sludge on the plug, but nothing more.  If you re-watch the video, the portion where I pan the camera down toward the radio, you hear me say when I let off the gas, at which time the noise just stops.  My co-worker says the noise is coming from up front, but he only sat in the passenger seat, and I've cocked my head back to listen to the back, and I myself am convinced its from the front.  I wish it was rear noise.  I am seeing what I can sell so I can buy a handy dandy steelman car noise detector kit.
If I'm going really slow and let off the gas, I can just barely hear a little of the same noise while coasting, but barely, and only for a second or two, not very pronounced.
So here are the facts:
Noise dominates solely on acceleration
There is a newer complete drive shaft
Car has 180k
Diff to transmission has small drip, so oil may have been run dry at one point by previous owner, big unknown
rear diff had fresh oil in it on purchase, but the front was low and burnt
transmission fluid is new, but brown when I got it
Sludge on diff plug upon first drain and fill
noise vibrates automatic shifter very slightly
recently installed new front axel
no play in front diff where axels plug in
noise diminishes at very high speeds
noise is constant after 25mph
noise is worst between 30 and 50 mph
Worst case scenario, how long might i get away driving it like this?
Front diff. Unless it's that cheap axle but I doubt that.
Hard to guess how long. Could be a day or a year.
I drove one to failure, took 18,000 miles I think but it was a different failure than yours. Mine was a "more minor" issue.
If it's the ring and pinion I think you'll find a sooner and louder/ more dramatic failure than bearings. You're going to get a loud bank or clunk one day and not be movable.
Edited by grossgary
Sounds like a reasonable confirmation Grossgary, not like the old days where I begged to differ about a head gasket. I was peterpan; just believe real strong and it won't be the head gasket, and then go for a good fly around Baltimore.
Wait a minute, am I hearing, I might be hearing something louder in the back that sounds like it's in the font? Let me get back to you...
That would be a nice hit.
What i normally try to do is have someone else drive and literally put my ears on the floor in the cargo area.  Do that, sit in passengers seat, sit up front, it should help determine front/rear and/or left/right.
  • Like 1
Myself and a coworker did just that last night. He said he thinks it's louder and it's coming from the back later after I dropped him off I reclined my seat all the way back and drove through the parking lot and I could definitely say the sound originates from the rear , SOB.
When I changed the differential fluids, I noticed the rear was new differential fluid and the front looked like it had been neglected, which tells me somebody was trying to quiet something down in the rear. As for the front, well I might've just saved it in time. Give me an hour or two I can change out a rear differential no problem.
If it's not a VDC and you have noise on accel only noise from rear diff should change if you put in the FWD fuse.
Noise is still there with the fuse in... Not sure if it's better, but still there, only had a short trip on my lunch
  • 5 weeks later...
Newbee here. First time owner of a 2004 Legacy Outback. How long can the fwd fuse be left in?
Probably as long as you want..but from what I've heard it's not worth it it's not going to save you anything on gas mileage so it's better to have it in Edited by Lverano
