GT Turbo 2.5 2005 needs 2nd Flex Plate in 2 years
Hi,
Clarify....you state Flexplate and Flywheel in the first post.....Flexplate = Automatic - 5EAT; Flywheel (FW)  = 5-speed manual....they both connect to the crankshaft.
Breaking a FW would be tough, so thinking you mean pressure plate, disk or?
Flexplate's do break on occasion.
How much boost/HP/Torque are you putting down? If stock, shouldn't break; 350+ just might?
TD
Edited by wtdash
 A little Googlin' found THIS.....basically the 4 TC bolts (4 on the 5EAT's?) weren't torqued properly....but getting a torque wrench on those is near impossible.
If you installed the 2nd one (that cracked) maybe an install issue (no offense)? If a NON-Subaru shop did it then, I'd find a real SUBIE shop.
GL,
Td
  • Like 1
