Treblemaker Posted August 13, 2016 Share Posted August 13, 2016 With two 93 loyale wagons (one since 94) I'm tired of replacing oil pumps because the filter bypass ball has been pushed out (Ok, it's only the third time since I've had the cars-- I guess I'm just annoyed that such a stupid design decision ruins an otherwise perfectly good pump). Thinking of replacing the pressed-in sleeve with a screw-in ring to hold the ball. My reasoning is that if the engine is turned backward for some reason I'd rather bust out the anti-drainback valve in the easily-replaceable filter than break the pump. Any thoughts on this? Bad idea? Good idea? Something I've overlooked? If it works I'll post pictures. 2 Link to comment Share on other sites More sharing options...
two85s Posted August 13, 2016 Share Posted August 13, 2016 Sounds interesting. I'll follow along. Cheers Link to comment Share on other sites More sharing options...
Crazyeights Posted August 13, 2016 Share Posted August 13, 2016 (edited) I have had to contend with this too. I'm interested. Edited August 13, 2016 by Crazyeights Link to comment Share on other sites More sharing options...
DaveT Posted August 14, 2016 Share Posted August 14, 2016 How does this happen? I've been driving EA82 engines since 1988. Never saw it. Link to comment Share on other sites More sharing options...
Treblemaker Posted August 14, 2016 Author Share Posted August 14, 2016 (edited) I doubt it would ever happen with an automatic transmission. With a manual, if it's parked in the wrong gear (ie reverse on a forward slope, or a forward gear on a reverse slope), and the driver removes the e-brake before pressing the clutch to start it, then the car may roll a bit turning the engine backward. If there's an anti-drainback valve in the filter, then the backward-turning oil pump will force the ball right out of the filter bypass check valve. Unfortunately not every driver pays attention to minute details such as, "which way does the car want to roll" when they park it. *sigh* Another way is using the clutch to hold the car on the hill and stalling it.("But why??!! You have "hill holder!") Edited August 14, 2016 by Treblemaker Link to comment Share on other sites More sharing options...
DaveT Posted August 15, 2016 Share Posted August 15, 2016 Ah, hadn't thought of that posabilty and combined circumstances. Link to comment Share on other sites More sharing options...
MR_Loyale Posted August 16, 2016 Share Posted August 16, 2016 (edited) I must have been totally lucky all these years. The way you park can kill your oil pump. Got to let that one sink in. Edited August 16, 2016 by MR_Loyale 3 Link to comment Share on other sites More sharing options...
Treblemaker Posted August 26, 2016 Author Share Posted August 26, 2016 Still experimenting. Meanwhile, I pulled an oil pump off an automatic at the pick-n-pull, so the car's back on the road for now. MR_Loyale, I agree, it's pretty weak design. Besides which, good filters already have an internal bypass (Purolator gold, for example). I have never seen another car with a filter bypass built in to the engine. Maybe the answer is to just plug the extra hole in the pump and be done. Link to comment Share on other sites More sharing options...
superooo Posted August 26, 2016 Share Posted August 26, 2016 Does this apply to ea81 engines? Ive been getting wierd pressure spikes and cant figure out why Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 26, 2016 Share Posted August 26, 2016 I doubt it would ever happen with an automatic transmission. With a manual, if it's parked in the wrong gear (ie reverse on a forward slope, or a forward gear on a reverse slope), and the driver removes the e-brake before pressing the clutch to start it, then the car may roll a bit turning the engine backward. If there's an anti-drainback valve in the filter, then the backward-turning oil pump will force the ball right out of the filter bypass check valve. ... As I live in the extremely mountainous Honduras, and with age and usage, the front parking Brake became weak and was not enough to hold the car, even with the manual transmission always on first gear; so I try to park my cars with the steering turned in order to let the front tires to touch the Sidewalk; but sometimes there's no sidewalk and the parking spot is pretty steep. That is the Reason why I successfully retrofitted a stronger, rear parking brake on my subie, years ago. However, prior to retrofit that, my "BumbleBeast" subaru rolled backwards being on first gear by itself, several times, slowly... once it even hit a parked luxury sedan that was brand new then, three meters away from where I parked, and my Subie was engaged in first gear as usual, and with parking brake set... the hill was pretty steep and no sidewalk, as we were in a rural area. So I guess that I've been Lucky with my EA82. I always use a Purolator oil filter that is a little smaller than the one for the EA82, but all the other specs are identical. Thank you for sharing this information, Kind Regards. Link to comment Share on other sites More sharing options...
