Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 (edited) I had checked all fuses I thought were related. But somehow not that one. It was popped. Put a new one in. Got door chime and radio working. Put some gas in the tb turned the key. It def sounded diff then before but the battery died after a few cranks. Tomorrow is a new day I suppose. Battery is on the charger. I will feel so dumb if it was just that. But quite honestly everything I've replaced needed attention and the wiring has to be cleaned up correctly to my standards Edited September 16, 2016 by Shortaay Link to comment Share on other sites More sharing options...
DaveT Posted September 16, 2016 Share Posted September 16, 2016 Let us know what happens. I have harnesses I can compare and FSM I can look stuff up in. It's be easier for you if you can find a full FSM as all of the harness details are in there. Sometimes we get bit by these sort of weird things, and the silly fuse is the problem. Frustrating as it can be, I figure at least it wasn't something worse / weirder. Link to comment Share on other sites More sharing options...
Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 I have a full fsm. Just need to print it off Link to comment Share on other sites More sharing options...
Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 I didn't get to go out and try before work this morning had to leave early I forgot to ask last night though does the coolant temp sensor and the oil pressure sensor on the front of the motor have anything to do with how it runs or is it strictly for gauges? Because both of those have about 2 inches of wire hanging off the front and nothing else in sight Link to comment Share on other sites More sharing options...
DaveT Posted September 16, 2016 Share Posted September 16, 2016 Coolant temperature sensor has 2 wires. Spfi has them, not sure about carbed. The temp gauge sensor only has 1 wire, no effect on running. Likewise oil pressure gauge. If it has a CTS and ecu, I've had those mess up drivability. Link to comment Share on other sites More sharing options...
Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 These are both one wire sensors right on the front and there's a yellow wire going to nothing in the harness at the top of the motor I think I'm just going to have to start taking pictures of some of this stuff and trying to get all this wiring sorted out whether it runs now or not Link to comment Share on other sites More sharing options...
DaveT Posted September 16, 2016 Share Posted September 16, 2016 Yes, that's what I'd do, just take it a step at a time. 1 wire sensors seem to be gauge only, at least in these cars, except the O2 sensor. Link to comment Share on other sites More sharing options...
Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 Soooo. It runs. I need to crawl back under it and finish hooking up the fuel pump and get some gas in the tank and see how it actually runs but with some gas in the tb it fired off I think I have a bad connection on the front driver spark plug wire can't get it to click on all the way I'll Tinker with it some more tonight and see what we can come up with Link to comment Share on other sites More sharing options...
Shortaay Posted September 16, 2016 Author Share Posted September 16, 2016 Fuel gauge is dead. So I need to tackle that. Time for some fluid changes and finish putting the the exhaust back on. Plus a few days worth or wiring work Link to comment Share on other sites More sharing options...
