kgolyaev Posted August 18, 2016 Share Posted August 18, 2016 I recently took my 2012 Subaru Forester X 4 2.5L to a mechanic, for an annual checkup. They found oil in the coolant reservoir, and told me they suspect a faulty head gasket. In their own words: Quote Found coolant reservoir empty, appears to have oil in it. This indicates head gaskets have failed internally. Radiator cap is swollen, suspect from oil. Advised customer return the car to dealer to inspect under warranty. I took the car to the dealer since it is still just barely under warranty (58.5k miles out of 60k that are warranty-covered). The dealer took the car in, and after a while responded that they think the PCV connector has a leak in it, which cases the oil to get into the cooling system. In their words: Quote Confirmed there is oil in the coolant reservoir and radiator cap. Coolant is coming from the PCV connector, which is a plastic breather connector that has a coolant running through it. Recommended replacing PCV connector and radiator cap. I called back my mechanic who was extremely surprised and said that what the dealership described is not possible mechanically. I am now completely lost and not sure who is wrong. Can anyone weigh in based on the data I presented? Thanks! Link to comment Share on other sites More sharing options...
idosubaru Posted August 18, 2016 Share Posted August 18, 2016 Yours is a non-turbo right? Subaru never used PCV valves with cooling lines, so mixing wasn't possible for many decades and would be the cause of hesitation from your mechanic (and probably many of us on this forum). Does the FB engine have coolant passing through the PCV valve or associated hoses? A quick glance on the internet seems to suggest that's not the case. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 18, 2016 Share Posted August 18, 2016 (edited) throttlebody 'MIGHT' be a possible - uh - 'intersection' ? of crankcase vapors and cooling system ?????????? I dunno, must be some car made in a different universe. seems crazy to me - I'd like to schedule a meeting with the mech or service writer to have him SHOW me this path of contamination. A leak from the trans cooler seems much more likely - check trans fluid level, you might consider sending coolant sample to Blackstone Labs or Polaris etc. and see if they can ID the oil or , hopefully not, find combustion products.. Edited August 18, 2016 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
idosubaru Posted August 18, 2016 Share Posted August 18, 2016 or oil cooler - oil and coolant both have passage through there as well. ? 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 18, 2016 Share Posted August 18, 2016 kgol - Joe Spitz that runs www.cars101.com works at Carter Subaru (shoreline ?) maybe contact him to see what he would suggest? - http://www.cars101.com/subaru/contact.html Link to comment Share on other sites More sharing options...
dmanaenk Posted August 18, 2016 Share Posted August 18, 2016 (edited) On 8/18/2016 at 10:32 AM, grossgary said: Yours is a non-turbo right? Subaru never used PCV valves with cooling lines, so mixing wasn't possible for many decades and would be the cause of hesitation from your mechanic (and probably many of us on this forum). Does the FB engine have coolant passing through the PCV valve or associated hoses? A quick glance on the internet seems to suggest that's not the case. Doesn't have oil cooler either, that the H6. Edited August 18, 2016 by dmanaenk Link to comment Share on other sites More sharing options...
Numbchux Posted August 18, 2016 Share Posted August 18, 2016 On 8/18/2016 at 6:15 PM, dmanaenk said: Doesn't have oil cooler either, that the H6. Splitting hairs here...lots of 4-cyl Subarus have an oil cooler, but a '12 Forester is not one of them. The PCV valve itself does not have coolant running through it, but there's more to the PCV system than just the valve. Bottom line. There DEFINITELY is not enough information here to condemn anybody, even if that's right off the repair order, and written by the tech, a few sentences does not give the whole picture. If the car is under warranty, I don't see any reason not to have them replace whatever connector they're referring to. It might not fix the problem, but this might be an odd one that will require a little experimentation to nail down, and waiting won't help. Link to comment Share on other sites More sharing options...
kgolyaev Posted August 18, 2016 Author Share Posted August 18, 2016 Thanks to everyone who replied to this thread! What kind of additional data would help to clarify the situation? I wanted to post some photos but I am ignorant enough to not know what should be photographed and what shouldn't be I am tempted to talk to another dealer to see what they have to say. For now, I am not driving the Forester if I can help it. Link to comment Share on other sites More sharing options...
keith3267 Posted August 20, 2016 Share Posted August 20, 2016 (edited) Its under waranty, the dealer has to fix it. If they want to replace a non existant part, OK but when that doesn't work, they still have to fix it, even if you go over the 60k miles. Keep all your documentation until you are satisfied it is fixed. Edited August 20, 2016 by keith3267 3 Link to comment Share on other sites More sharing options...
DJI Posted September 11, 2024 Share Posted September 11, 2024 I do know on a 2012 Subaru Forester there is a part called the PVC Hose Connector (which isn't the PVC valve). It is a connector with 2 hoses -- one is water and one is a breather hose (vacuum). This will leak oil residue into the water if the o-ring is bad. Poor design to put those 2 hoses on the same piece of plastic. Link to comment Share on other sites More sharing options...
