Ionlyhave3suubs Posted August 20, 2016 Share Posted August 20, 2016 I have just recently gotten back into wrenching on Subarus again. It has been a little bit since I have done any gasket work and I want to make sure I have good information before I start laying down hard earned money for parts. 1. I am looking to put together a frankenmotor with a 97 or 98 2.5 DOHC shortblock and 95 2.2 heads. Both EGR compatible. I understand I need to use 2.5 oem head gaskets. I have heard some recommend gaskets for a 2.5 turbo engine for this application, but have not heard a specific part number or vehicle type to order turbo gaskets for. 2. I believe I am correct that the remaining gaskets needed can be sourced aftermarket without issue, keeping in mind that cam and crank seals need to be the brown rubber, not the black. Fel-pro etc. ok for valve cover, intake, exhaust, oil pump, etc.? 3. Oil separator seal- Grey RTV good? I'm installing the steel oem replacement. 4. I read the thread on the Gates timing belt kits. Any other recommended aftermarket supplier manufacturer/supplier? 5. Different vehicle- 2006 Forester NA 2.5 SOHC- It is due for timing belt again coming up on 200k miles. Head gaskets are seeping oil at a slow rate. Minor annoyance, but I will probably do the head gaskets and timing belt all at once. I have never worked on one of these engines but expect it to be similar to the 2000 and 2002 sohc 2.5s I have done timing belts on before. Anything else I need to do while I am in there? Do I need to pull the oil pump and check the screws? anything else? Turbo or NA head gaskets? OEM or aftermarket? 6. The head gasket tightening steps? The information in my old Haynes manual I don't believe is accurate. Can someone post the head torqueing instructions for my 97 and my 06 please? Link to comment Share on other sites More sharing options...
Ionlyhave3suubs Posted August 20, 2016 Author Share Posted August 20, 2016 I am not sure what happened on the double posting, please reply to the other post. Link to comment Share on other sites More sharing options...
