Have a 1991 Subaru Legacy that runs on gas and gasoline.  Recently when running on gasoline the car has a hesitation when accelerating, when on gas it is just fine.  Wondering if its  a fuel filter problem or what else it can be?  The gas side has its on filter. Thanks
There is a separate tank under pressure in the trunk, gas prices are cheaper in Europe,
they have conversion kits.  You can run both , changing with a switch on dash.Channging from gas to gasoline on the fly. Separarte injectors for gas.
I changed the fuel, air filters, no luck. I will check status of engine light. Need to buy tool.
I disconnected spark plug wires one at a time, spark working.
Edited by Zigster
