Big e Posted August 28, 2016 Share Posted August 28, 2016 Just bought 02 went through car wash and found 3 to 5 inches of water in spare tire well looks that down by lower frame missing piece which allows water to drain out not sure any ideas thanks big e Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 29, 2016 Share Posted August 29, 2016 you might look around at www.opposedforces.com for a drawing of what the seal looks like - I have no experience with sedans. or, a collision center might be able to fix this for you. Link to comment Share on other sites More sharing options...
gbhrps Posted August 30, 2016 Share Posted August 30, 2016 Big e, You don't say if you have a sunroof, because the rear drain tubes of the sunroof exit the car between the rear bumper cover and the rear quarter panel. If a tube has cracked or come off at the top, water could find its way into the trunk area and spare tire depression in the floor. If that's not it, it could be the rear windshield needs resealing, or the tail lights the same thing. The absolute last thing to consider is the trunk seal itself, seldom the issue. Good Luck! Link to comment Share on other sites More sharing options...
