Timbum36 Posted September 1, 2016 Share Posted September 1, 2016 Transmission only has 1st and 3rd gear setting a code of line pressure selnoid every thing was working fine until the new engine was put in can't find a bad connection but the code was set before engine was put in help please Link to comment Share on other sites More sharing options...
wtdash Posted September 2, 2016 Share Posted September 2, 2016 Hi and Welcome to the USMB, Did the Torque Converter come out ...even a little bit..when you pulled the engine? If so, are you 100% sure you re-seated it properly? Td 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 2, 2016 Share Posted September 2, 2016 ^^^ what he said, easy to crack the pump. also, did the trans pan get dented? even a little? easy to mess stuff up on the other side of the pan. 1 Link to comment Share on other sites More sharing options...
Timbum36 Posted September 4, 2016 Author Share Posted September 4, 2016 Yea it looked like the pan was pushed up I have taken the pan off haven't found anything have check the wiring it all looked good Link to comment Share on other sites More sharing options...
CNY_Dave Posted September 6, 2016 Share Posted September 6, 2016 The pan pushed up just a little can do it with no other damage- it restricts flow into the intake. 1 Link to comment Share on other sites More sharing options...
Timbum36 Posted September 6, 2016 Author Share Posted September 6, 2016 Replaced the pressure line selnoid it fixed the problem thanks a lot guys you have been a great help love this web site Link to comment Share on other sites More sharing options...
