90 loyale suddenly quit
My 90 loyale recently kind of sputtered momentarily at highway speed.  Then days after suddenly quit at idle in traffic, slightly backfired.  I borrowed a fuel pump guage and put it in line of fuel filter.  Reads 20 psi.  Can anyone please help?
Does it crank with an even rhythm, or uneven?
Pedal down and crank is flood clearing mode.
1 or 2 seconds of carb cleaner into the air intake will make it run for a few seconds if the spark, timing and distributor are all good.
Pull one of the smaller hoses to squirt it in toward the throttle body.
Thanks all, was rotor set screw loosening and falling out eventually.  Pain.  Does anyone have a shortcut on the ridiculous set screw other than pulling distributor to place set screw for next tune up?  She is fixed!
