oderus Posted September 5, 2016 Share Posted September 5, 2016 (edited) New to forums,Working on my daughter 01 Legacy ,first sub .Did head gaskets earlier this year, a little hesitation first off the throttle but run good on top end 02 sensors were bad but ran good recently went for state inspection failed because of sensors but were bad last year .Installed new sensors cats are good ran fine until warmed up threw a p0341 code replaced still code is there sensor ohmed okay plugs are black .Any advice would greatly appreicated , also timing is right on thank you in advance and everything was new belt ,plugs pulleys water pump tensioner Edited September 5, 2016 by oderus Link to comment Share on other sites More sharing options...
wtdash Posted September 5, 2016 Share Posted September 5, 2016 HI and Welcome to the USMB, That is a P0341 - Camshaft Position Sensor Circuit Range/Performance code....nothing to do w/the O2 sensor. Typo on the code #? Link to comment Share on other sites More sharing options...
