musubk Posted September 9, 2016 Share Posted September 9, 2016 I'm tired of having a gaping hole in the floor where the shifter sticks through, so I'm going to make a shift boot soon. I'd like to see what some other people have done for this. Link to comment Share on other sites More sharing options...
dfoyl Posted September 9, 2016 Share Posted September 9, 2016 I still use the factory shift boot, but I cut the metal frame down into a U-shape with the section facing the back of the vehicle being cut out. Link to comment Share on other sites More sharing options...
skishop69 Posted September 10, 2016 Share Posted September 10, 2016 Obviously you've cut the floor to fit it in so you'll have to modify a factor console to work or buy an aftermarket boot kit. I modified the shelf the shifter mounts to as well as the linkages so it sits in the same hole which I believe is what most do. Jerry sells a kit with all the pre-fabbed parts to install so it goes through the factory hole.. Link to comment Share on other sites More sharing options...
