superooo Posted September 10, 2016 Share Posted September 10, 2016 If anyone has any pictures of the relay area on an spfi swap i would greatly appreciate it, i have a bunch of extra relays and have my harness mostly prepared but want to do my fuses and relays clean and proper Also in need of some pictures of the maxima alt swap, particularly your pulley and spacer if you have some after you ground it down, also where does this ground wre on the alt housing go? Dont see one on my alt, and all the pictures in the write up are dead... going into ea81 hatch Link to comment Share on other sites More sharing options...
skishop69 Posted September 10, 2016 Share Posted September 10, 2016 (edited) Can't help with the SPFI swap as I have yet to install mine, but the alternator does not have a ground wire. It grouns through the case. One single wire connection to the stud on the alt and the plug with two wires for the regulator. Depending on which version of Maxima alt you have, it may plug in or you may need to remove the terminals from the housing and plug them into the alt. Also, you can remove them from the housing and install them into the Maxima housing if you snagged it. Edited September 10, 2016 by skishop69 Link to comment Share on other sites More sharing options...
superooo Posted September 10, 2016 Author Share Posted September 10, 2016 No like it has a 2 prong plug and the main wire held on by a nut and another mystery wire held on by a different nut, looks like a ground but i could be COMPLETELY wrong Link to comment Share on other sites More sharing options...
superooo Posted September 11, 2016 Author Share Posted September 11, 2016 Got the alternator in and running, the wire i wasnt sure about was a housing ground, next to an E in the housing, i jus grounded it to the body with no issue, runs a lot better, best swap ive done yet, thanks to gd's write up Link to comment Share on other sites More sharing options...
superooo Posted September 13, 2016 Author Share Posted September 13, 2016 Still need relay pix for ea81 spfi swap as gds write up kinda breezes over it without showing what he relayed and what fuses Link to comment Share on other sites More sharing options...
