nutt7 Posted June 10, 2004 Share Posted June 10, 2004 there is one at the jy here and it had some fire damage under the hood...It doesnt look too bad, except most things plastic or rubber are melted. Do you think the spider intake is ok, so long as I clean it up real well? Also, do these have lsd in the rear diff? easy way to tell? will the sway bar in the rear work on my 86 wagon? It also has a cooler of some sort in front. It is an auto, does that mean its a tranny cooler (driver side)? everything is under the hood still. anything else worth taking? eric Link to comment Share on other sites More sharing options...
ShawnW Posted June 10, 2004 Share Posted June 10, 2004 LSD: Check for a sticker. If there isnt one jack the rear and turn a tire, if both turn the same direction its LSD. Hard to say on the fire damage. The metal of the intake might be good but dont you need sensors and such that are specific to it? Link to comment Share on other sites More sharing options...
nutt7 Posted June 10, 2004 Author Share Posted June 10, 2004 Shawn, I would think the intake would require sensors specific for my computer, I just dont know if the spidey has any extra or less sensors...If the metal looks ok, I may just snag it anyway...I think they will charge me $20 or so Link to comment Share on other sites More sharing options...
DerFahrer Posted June 10, 2004 Share Posted June 10, 2004 Spider intake on an 86?? I thought that started with 87.5's... Link to comment Share on other sites More sharing options...
nutt7 Posted June 10, 2004 Author Share Posted June 10, 2004 the date on the placard said 86 so I guess it probably is an 87...but it definately was a spider intake... Link to comment Share on other sites More sharing options...
