pbilt Posted September 13, 2016 Share Posted September 13, 2016 There are 2 vacuum lines on the distributor do I need to plug one and plug the other one to the port on the bottom of the carb or do they both plug into somewhere and if I need to plug one witch one gets plugged thank you Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 13, 2016 Share Posted September 13, 2016 One vacuum port at the distributor, is for steady vacuum -outer one- while the other port needs Progressive vacuum -inner one- so, you should cap close the outer one on a Weber Swap, and plug the inner one to the Weber's front-left port. Read further information here: ~► http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ Kind Regards. 1 Link to comment Share on other sites More sharing options...
pbilt Posted September 14, 2016 Author Share Posted September 14, 2016 (edited) Thanks man I love it when you reply to posts you always explain everything perfectly I already read that link I bought the carb from someone on here and they sent the manifold with it. It has the 2 piece adapter plate but oh well I'll run it the cooling port was welded already so that was nice when I redid the carb it had 16s for the secondary and 17s for primary jets does that sound right he was running it on a ea81 with a ea82 intake manifold Edited September 14, 2016 by pbilt 2 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 14, 2016 Share Posted September 14, 2016 Thanks man I love it when you reply to posts you always explain everything perfectly... Thank you for your kind words, which are really appreciated. ...the carb it had 16s for the secondary and 17s for primary jets does that sound right ... Are you writing about the main fuel Jets? If so, please refer to my Writeup whose link is on my post above; there is a post where I wrote regarding the use of different fuel Jets. Kind Regards. Link to comment Share on other sites More sharing options...
pbilt Posted September 15, 2016 Author Share Posted September 15, 2016 I reread your link the one I read wasn't that long I booked marked it thank you again that covered literally every question anyone could ever have Link to comment Share on other sites More sharing options...
robm Posted September 15, 2016 Share Posted September 15, 2016 JesZek is on the list of people I would most like to buy a beer. Excellent knowledge and advice, delivered with humour and respect. 5 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 19, 2016 Share Posted September 19, 2016 I reread your link the one I read wasn't that long I booked marked it thank you again that covered literally every question anyone could ever have JesZek is on the list of people I would most like to buy a beer. Excellent knowledge and advice, delivered with humour and respect. Thank you for your kind words, which I really appreciate. Link to comment Share on other sites More sharing options...
