2014 2.4i Legacy with CVT, Tire size difference tolerance?
Had a flat yesterday, tires are pretty new <10Kmiles on them, very little thread wear. thinking on replacing only that one.
tirerack says the full thread depth spec is 10/32", I measure 9/32" with my caliper.
Searched the owner manual and found no mention that it may damage AWD?
IIRC for my previous 02' and 2010' Legacy there used to be some acceptable tolerance on the tire diameter difference, but see nothing here?.
Is the difference in tire diameter (circumference) no longer an issue with the new AWD drive for this MY?
-Michael
Called a dealer service department, they said as long as the thread is "good" it's OK to replace just one tire but it has to be the same brand/model. Looks like the newer AWD system can tolerate diameter/circumference differences that are as large as whatever is due to the thread wear over the tire lifetime?
