CV axle?
I'm hearing a "Grumbling" noise coming from the front right of the car as I am driving (40-50 mph) and also on right hand turns. I have read about  "clicking" noise from the cv axle when they go bad do ya'll think it could be the same thing? That axel has about 60k on it while the left side has I'm assuming 174k what gives? lol
Thanks!
Took a look at it and didn't hear a grinding noise when I spun the tire. I felt some play when I moved the tire typical to bad bearings. I noticed that my castle nut was moving and I could jiggle it with my fingers. The cotter pin was still in place so I couldn't take the nut off. I tightened the castle nut and drove it around the block no issues. So I guess I'll keep an eye on it.
  On 9/21/2016 at 7:46 PM, ClassySoob said:
does it usually only happen at one speed, or is it constant when the rig is in motion?
In motion and I would say intermittent. Sometimes I hear it at low speeds 35 mph and also at high speeds 65 mph. But since I tightened my castle nut I haven't heard it at all.
  On 9/23/2016 at 8:55 PM, grossgary said:
that loosness was definitely the issue.  will it come back?
In my experiance, once this happens the hub is toast. Ive had it happen a couple times now. I try to keep extra hubs in stock but they arent always easy to find and many times when Im at the j-yard I dont have my giant sockets with me.
I have been driving it for the last couple days and it seems fine so far fingers crossed lol
Ive never figured ot if this is caused by the condition of the hub/axle splines, an issue with the conical washer/seat, lock washer or an installation issue. When it starts the splines seem to get "thinned". The first time it happened to me it was on a recent purchase. I tightened and many months later it returned. Retourqed and then a couple months later I replaced the hub on that side and it never happened again. The splines were no longer a tight fit. Oddly enough the axle splines seem unaffected. Ive had one completely stripped out and reused the axle with a different hub.
The axles are hardened, the hubs are just cast. For the splines to be worn like that, it was loose for a good while. How one gets looose, yeah, odd. There isn't really any normal way for anything to wear - the parts are all stacked and compressed by the big nut. If it was assembled correctly.
When I did my brakes was the last time I had the hub off probably a year ago. I didn't have the correct size socket so I just used a big crescent wrench and tightened them up as much as I could. I'm not sure how this one got loose beings there is a cotter pin preventing the nut from spinning. I only recently heard the noise coming from that side. It was intermittent so I wrote it off. That car makes all kinds of different noises so I would be a real busy guy if I tried to track them all down lol. I checked into this noise because it was new and I heard it a few times more frequently. Anyway I will check for tightness in another day or so. Probably time to expand my socket collection to torque them down properly. Oh darn I have to get more tools :P
  On 9/27/2016 at 8:55 PM, DaveT said:
It's not likely you got to around 150ftlbs without a big breaker bar or handle extender. It seemed tight, but with heating and cooling and the dynamic loads from driving, things shifted and the looseness became apparent.
I was pretty much right on the money. I bought a socket and checked the torque of all 4 axel nuts and they were all pretty close to 150 lbs. So, with that said, a 235 lbs. guy standing on a 12" crescent wrench adding 3-4 bounces is equal to 150 ft lbs. of torque. It is proven science :P
  • Like 1
