wduzak Posted September 21, 2016 Share Posted September 21, 2016 I'm buying catalytic converters kit online and having my mechanic put it on. Two spots for sensors. Can I use universal O2 sensors on both or do I need specific sensor for each one?? It also looks like sensors online are much cheaper than at auto parts stores. Any opinion? Thanks for the help Link to comment Share on other sites More sharing options...
matt167 Posted September 21, 2016 Share Posted September 21, 2016 you could get away with a universal downstream for the rear. I would recomend against it tho. The upstream you need an OEM type sensor. IIRC OEM is Denso, and I would stick with Denso. You can get an aftermarket Denso, or one from the dealer. It is VERY important since the upstream adjusts the air/fuel ratio and the ECU is programmed to adjust from a set of ranges. If those ranges are off, it could run bad or throw a code Link to comment Share on other sites More sharing options...
Rooster2 Posted September 22, 2016 Share Posted September 22, 2016 Recently replaced the up stream O2 sensor on my 99 OBW with a Bosch oxygen sensor part # 13702, after CEL thru a code that the oxygen sensor was bad. The Bosch sensor works great, with my car running better then before the CEL. With on line discount coupon, cost from Advance Auto Parts was $59.XX. Link to comment Share on other sites More sharing options...
lmdew Posted September 22, 2016 Share Posted September 22, 2016 I have a couple good CATS in Colorado that would bolt right in. Link to comment Share on other sites More sharing options...
