A problem solved! Axle related
All,   I had a bad vibration in the left front axle for a short time and thought that the axle had gone bad again. Thing about it was that the axle would make noise on a straight and in corners. Especially in corners uphill in passing gear.  I took it to my friends shop and he did a simple test of the motor mounts and thought that the left mount was weak but not broken.  He changed the mount today, no more vibration on the axle and it drives perfect again.  I guess the angle of the motor and the angle of the axle in passing gear were way to much and caused a feeling almost like torque bind.
Hopefully this is the last of the problems I have to get fixed for winter driving!
Mark
