ToySuby Posted September 25, 2016 Share Posted September 25, 2016 2003 Outback Limited EJ25, built for Canada in May of 2002. 165,000 miles. I cleaned and flushed the cooling system in March 2016. Then drained the block, radiator, heater core, etc. and removed the freeze plugs, all hoses, thermostat, temperature sender, etc. to dry the system out. Now ready to install new hoses and Evans coolant plus dozens of other preventative maintenance items. Was at the dealer last week and overheard someone say that it's hard on the head gaskets to let them dry out like that. Do not even think of putting it back together. Replace the head gaskets, guaranteed to have an issue with the head gaskets. I wish I had a chance to engage in the conversation. The head gaskets were replace in April, 2011 around 110,000 miles. It appears they are the Subaru brand. All other parts are Subaru. Have not found any aftermarket parts, including filters on the Outback. Is this a myth, a rumor, or a fact that I should continue deeper into the engine and replace the head gaskets? http://www.evanscoolant.com/ http://www.discountoeparts.com/genuine-subaru-parts Link to comment Share on other sites More sharing options...
john in KY Posted September 26, 2016 Share Posted September 26, 2016 I don't believe what you overheard. Crate engines eg can sit for years without coolant before being sold. Link to comment Share on other sites More sharing options...
DaveT Posted September 26, 2016 Share Posted September 26, 2016 I'd put it in and see what happens. But to me swapping an engine isn't a big deal, so if it developed a problem, no big deal, I just lost some time. I've had engines I pulled sit around for years, and then put them in and run them. I didn't drain them of coolant though, just whatever was left was left, and then evaporation likely happened. I never head of any trouble from sitting dry. 2 Link to comment Share on other sites More sharing options...
montana tom Posted September 26, 2016 Share Posted September 26, 2016 +1 on daves post. I have never heard of head gaskets going "dry" Put it back together and run it. Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 27, 2016 Share Posted September 27, 2016 Head gaskets are metal. Metal doesn't dry out. Valve cover gaskets or other o-ring type or rubber gaskets can be said to be "dry" when they get old and harden and crack due to volatile vapor exposure. But head gaskets aren't affected by petroleum. Plenty of reasons that can cause head gaskets to go bad, sitting around with no coolant in the block isn't one of them. Link to comment Share on other sites More sharing options...
idosubaru Posted September 27, 2016 Share Posted September 27, 2016 Hahaha. That's hysterical. Carry on. Link to comment Share on other sites More sharing options...
ToySuby Posted October 2, 2016 Author Share Posted October 2, 2016 Thanks for your experiences and common sense. I'll chock this up to; never listen to a service writer that has not been a technician. There just a salesman. Link to comment Share on other sites More sharing options...
