cas5259 Posted September 27, 2016 Share Posted September 27, 2016 (edited) Finally got the engine finished up yesterday and when it started, the revs went right up to 2500. I adjusted the throttle cable with little to no effect. Good news is that it was running smooth. I let it go to top off coolant and inspect for any leaks. A minute later, the engine speed starts jumping around between 1500 and 3000. It settled down and then the engine light came on: P0519. I erased it, and the revs started jumping again. No vacuum leaks I could see, and I never touched any of the sensors on the throttle body - IM came off in one piece. Every time I erased the code, it would jump around, then settle around 1500. I ran it this morning and wiggled the harnesses/vacuum lines but got the same thing, plus with 3 pending codes: "B2ERR - Body", "DAT -", and "P1900 - Powertrain". I've never heard of those. When its idling high, its smooth....but when the revs settle down into the 1500 range there is a small vibration. One irregular thing that happened during the rebuild process is the TC come off when pulling the engine, but I'm confident that I assembled and installed it correctly. Snapped the clip back into the shaft and got it installed to factory spec. When the engine was fully bolted up, I could turn the flex plate easily to get the bolt holes lined up. Other than that, it was business as usual. Any guesses to the root cause? I'll try and clean the IAC sensor tonight. Edited September 27, 2016 by cas5259 Link to comment Share on other sites More sharing options...
cas5259 Posted September 27, 2016 Author Share Posted September 27, 2016 Found the cruise control cable holding the throttle way open. Must have checked the throttle and not cruise. She purrs! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 27, 2016 Share Posted September 27, 2016 what car? there was a recall for clip on gen 2 H6es to prevent CC cable interference. Link to comment Share on other sites More sharing options...
cas5259 Posted September 28, 2016 Author Share Posted September 28, 2016 On 9/27/2016 at 11:11 PM, 1 Lucky Texan said: what car? there was a recall for clip on gen 2 H6es to prevent CC cable interference. '06 Baja SOHC. Just an error on my part. I must have moved the nuts by accident at some point. 1 Link to comment Share on other sites More sharing options...
