truvkngfan Posted September 27, 2016 Share Posted September 27, 2016 While driving at typical cruising speeds, the car occasionally (every 30 seconds to every 5 minutes) will have the engine rev for a quick second, and when it comes back to a normal rpm there will be some sort of belt squeal. This has been happening for the last 3 months and typically more after the car has been sitting for several hours. Any ideas on what could be causing the problem before I bring it in? Thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 27, 2016 Share Posted September 27, 2016 Hows the fluid level? Condition? How many miles on the car? Has the fluid ever been changed? Is this the 5 speed auto or the CVT trans? Link to comment Share on other sites More sharing options...
idosubaru Posted September 27, 2016 Share Posted September 27, 2016 +1 to what he said. While driving at typical cruising speeds, the car occasionally (every 30 seconds to every 5 minutes) will have the engine rev for a quick second, and when it comes back to a normal rpm there will be some sort of belt squeal. Thanks! In genearal - Possible transmission issue: Check fluid level. Link to comment Share on other sites More sharing options...
truvkngfan Posted September 27, 2016 Author Share Posted September 27, 2016 Hows the fluid level? Condition? How many miles on the car? Has the fluid ever been changed? Is this the 5 speed auto or the CVT trans? The car has the CVT transmission and currently has 120k miles. I am not sure on when the last time the transmission fluid was changed. I did look at the manual and there seems to be no way to check the fluid level on the CVT transmission. Link to comment Share on other sites More sharing options...
Silent Bob Posted September 28, 2016 Share Posted September 28, 2016 Flare and or shudder, with a terrible metallic screech likely means the chain in the CVT is slipping. Prepare your wallet for a new trans. Link to comment Share on other sites More sharing options...
