EJ20G valve cover gasket
Where do you get your valve cover gaskets from? I really dont want to order online and wait weeks for new gaskets to arrive, lordco/napa etc dont order anything "jdm". My question is, is there valve cover gaskets, spark plug gaskets that will fit off of a car from north america? motor is a EJ20g, out of a 90 legacy
Thank You,
There is no usdm gasket equivalent for the 1st gen legacy ej20g.
I was just going to suggest the '96 EJ25D version...no go either? But I've read that those early Legacy EJ20G's were....unique.
There may (not) be some useful info from this Thread on the LC BBs.
I 2nd the partsouq.com resource...but you'll need a part number, AFAIK.
Edited by wtdash
I tried to look it up with Opposed Forces. but it only goes back to 1993 EDM which did not have a turbo at that time.. The other resource is www.japanparts.com which has part diagrams and you can gain part numbers. You could also order from them. Sites a bit slow tho
Partsouq requires a chassis number to look up parts. Otherwise you have to search a P/N yourself and see if they can get it.
  • 2 weeks later...
Bump!
Went to do the valve cover gasket and found out it wasnt the gasket leaking after all, as it turns out, the metal around the spark plug is broken right off, is this something that is jb weld-able? or is the head screwed? i circled the part thats broken off in the attached picture.
