mjowoody Posted September 28, 2016 Share Posted September 28, 2016 Found that my ignition amplifier is weak/dead, car will not spark, I've only found 1 source in the whole country and they want 360$$ for it. No old subaru's in any of the junkyards around here either. Hoping someone has a parts car that has one and would be willing to sell me, Its the little module directly under the ignition coil bolted to the bracket. Thanks in advance -Woody Link to comment Share on other sites More sharing options...
john in KY Posted September 28, 2016 Share Posted September 28, 2016 (edited) That module uses the coil bracket for its ground. Won't work if not grounded. Make sure the bracket has a ground before replacing that part which is actually part of the coil bracket. Finding a used one should be ultra easy as that part just never fails. Also check for a broken timing belt. Edited September 28, 2016 by john in KY 2 Link to comment Share on other sites More sharing options...
mjowoody Posted September 29, 2016 Author Share Posted September 29, 2016 Thanks for replying. grounds good, it's at the shop right now, mechanic traced the issue to the ignition amplifier, looked everywhere, the part doesn't really exist on the internet. Link to comment Share on other sites More sharing options...
Shortaay Posted September 30, 2016 Share Posted September 30, 2016 you looking for the one on the coil bracket? I have an extra Link to comment Share on other sites More sharing options...
Rstnall4 Posted January 29, 2017 Share Posted January 29, 2017 Interested to see if this fixed the problem. Bump Link to comment Share on other sites More sharing options...
