jangelore Posted September 29, 2016 Share Posted September 29, 2016 Hi, New here, searching for answers for a strange 'problem' that my mechanic can't diagnose (at lease not without dropping $200+). My '03 Legacy Outback 2.5 is making a strange sound between 200 - 1200 RPM (approx). The car has 175,000 miles on it, and generally runs very well. It did get low on oil at one point some months ago, so not sure if that contributed. But I have done two full engine flushes, as well as a fuel system flush, and new plugs, and the car really seems to be running better than ever... except for this odd 'clacking' sound. Another mechanic I know who did not actually hear the car, said it may be some sensor or something in the fuel system path, and I guess I'm just tryong to find out if anyone has had a similar issue. Thanks for any info you might provide. Regards, Joe Link to comment Share on other sites More sharing options...
DaveT Posted September 29, 2016 Share Posted September 29, 2016 Low on oil? how low? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 29, 2016 Share Posted September 29, 2016 some folks have weak timing belt tensioners make a noise 'similar' to piston slap and rod bearing failure. There are even 3-4 youtube videos about tensioner noise. 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 29, 2016 Share Posted September 29, 2016 Timing tensioner failing, cogged timing idler bearing failed, cracked flex-plate, bad rod bearing... Could be any number of things. Hard to say without hearing it. Any way you can post a vid of it? Link to comment Share on other sites More sharing options...
somick Posted September 30, 2016 Share Posted September 30, 2016 Torn CV boot? Link to comment Share on other sites More sharing options...
jangelore Posted October 3, 2016 Author Share Posted October 3, 2016 Hi, thanks for all the replies, the cause of the noise was a toasted timing belt tensioner. A good family friend who is also a great mechanic fixed it for me this past weekend (I was able to get the pulley kit and new belt from Advanced auto). All in all I feel lucky because the alternatives could have been really bad. Thanks! 1 Link to comment Share on other sites More sharing options...
