Need to drill a 2.5 2003 Non EGR head need drill bit sizes and tap sizes?
Does anybody have the drill bit and tap sizes for an EGR port for a 2003 2.5 left head?
Caboobaroo mentioned he had it, but he has been off line for a couple of days.  Have the head and need it ASAP.
I will take pictures and post this once I have the proper drill bit size and tap size for people in need of this in the future.
That is an awesome workaround. I have to look at how it would work for the 2003 2.5 I have..   My motor is out of the car and the head that was original is bad, so the tap is not hard with the head out of the car.
The posted workaround works, but there is a simpler way.
Cut the egr tube in half, rotate it 90 deg. facing pass side.
Take the iac hose and the cut egr to auto store and get a foot of the size that fits it.
There is another fitting that will go over it that will make a tight fit into the iac hose.(not sure of size)
If you don't have another iac hose around get a foot of 3/4" ID hose of any type.
Get a 3/4" T barb. Plastic is fine
Hose clamps is all else you need.
Lay it out as you install it so that you cut the iac hose in the right places.
Will post pics as soon as I get to the car that the mod is on.
O.
Edited by ocei77
Yep, works great.  I've used a spare Brake vacuum line, just make sure the check valve allows the EGR to pull air.
Ace Hardware, Plastic hose barb Tee with a brass hose barb reducer screwed into it.
Works Great
