94 dual range swap!
Ok so I recently bought a parts car (86 gl wagon) with a dual range transmission I plan on putting in my 94 loyale. From what I've read so far it's pretty much a straight bolt up? Do I need to use the rear diff out of the gl? Or are the rear diff gear ratios the same? I know I might have to splice on to the wiring harness.
Any tips would be greatly appreciated.
Thanks everyone! Just got it all buttoned up. Took me about 4 hours. I didn't have to splice in to any wires, I was able to unplug them further back and then the dual range harness plugged right in. Reverse lights work and 4wd indicator comes on the dash. All I need is some new manifold gaskets, tried putting back togeather with the old ones leaked pretty bad. Can't wait to take it out and play around a little!
  • Like 1
I just plugged them. I wasn't really sure what to do with them either. I'm also experiencing a really low idle. Like 2-300rpm before I swapped it it idles around 6-700 rpm. Not really sure where that came from. I looked all over for a vaccum line or something I may have knocked off but couldnt find anything.
