94 loyale bare and broken wires under dash
This is what im dealing with i didnt think about croping them
In the 1st pic, those wires appear to have been smashed together enough to destroy the insulation. That caused a short, and heated the Black wires enough to burn off the insulation on them, also burning those wires in two.
The pic in post #11 shows even more  of those burnt wires.
It also shows a Blue wire that appears to have been burnt in two itself.
Look at the upper left of center in that pic and you'll see it
Not 100% on it, but it looks like there is heat damage to the insulation of other wires in all of your pics.
Here is the back of a fuse block.  EA82 Not sure what year.   Most should be the same.
If you can find a FSM - either in paper or online download, and can identify the wires you are missing / burned / broken I [and likely others]  can more easily identify them.
I have a 90 FSM.  A few things are different - My 92 and 93 have those annoying motorized lap belts.  My 90 and older had regular ones.  So far, the 90 manual has been good for the 92 and 93.
