sumoco Posted October 11, 2016 Share Posted October 11, 2016 So i had one made for my 6 inch lifted BRAT but I think I had ADF make it too long and it was super jumpy and finally stripped out while I was driving down the road the other day. Does anyone have one laying around I could buy or could someone help me determine the length of the extension needed. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted October 12, 2016 Share Posted October 12, 2016 iirr i used a ea82 manual steering rack 2 joint linkage. I clearanced out the joints so they wouldn't bind with a burr and had to drill a new slot on the steering shaft for the column. You could just go to pick n' pull and pull a couple of them off a legacy, loyale, gl, or impreza. To extend it you would cut one of those double joints apart then bolt the two pieces on. After that you would measure how big of a piece of rod or thick wall tubing you would need to weld in. Link to comment Share on other sites More sharing options...
Uberoo Posted February 2, 2017 Share Posted February 2, 2017 Another thing you can do is use a dremel with a cut off wheel and carefully cut new splines further up the steering shaft,then cut off the original splines. You will still need a longer steering extension but it will reduce the operating angle of the steering shaft so it will be less prone to failure in the future. Link to comment Share on other sites More sharing options...
