skiahfrazier Posted October 11, 2016 Share Posted October 11, 2016 Hello Folks, I have had a very lucky find that I was able to purchase. It is a 1986 Brat with the EJ22 already swapped in. This car was purchased by the previous owner from someone in Florida. It had a lift kit and Peugot rims. It has a 5 speed all wheel drive transmission, how do i tell which transmission this is? There does not appear to be any custom driveshafts, is this possible? Also the guages work sporadically, Voltage and Temp drop to zero randomly. I am guessing there may be a bad ground somewhere. Anyone have experience with that? These are the only problems i have found so far, the car did pass inspection and I am enjoying driving it for short trips, loads of fun. Thanks Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 12, 2016 Share Posted October 12, 2016 Welcome! Maybe there are loose plugs on the wiring harness, worth check it, as it should have been spliced to wire the instrument cluster; also the Transmission might be the one from the same Subaru that was the Engine donor... Share Photos of your Brat! Kind Regards. 1 Link to comment Share on other sites More sharing options...
