foxgap Posted October 13, 2016 Share Posted October 13, 2016 All, I am going to use this cleaner from a very good company, got a brain fart at the moment so I can't pull up the name. Should I disconnect the air tube at the throttle body or blow the stuff down the tube from the end at the air cleaner? If I do the cleaning right at the throttle body am I going to set a code? Car is a 95 Legacy 2.2 auto. Thanks, Mark Link to comment Share on other sites More sharing options...
montana tom Posted October 13, 2016 Share Posted October 13, 2016 Clean at the throttle body, no sense cleaning a plastic tube. Will it set a code ? maybe... just clear it. Disconnect the battery for 30 minutes , go to parts house and have them clear codes or.... spend 20 bucks and buy a cheap reader and then you will have one of your own. Link to comment Share on other sites More sharing options...
foxgap Posted October 13, 2016 Author Share Posted October 13, 2016 Thanks, That is what I thought. BTW the stuff is made by AMSOIL. Link to comment Share on other sites More sharing options...
