Spider Intakes, whats the difference
There is an EGR on the turbo spider intake because I have one sitting next to me :) . There is no EGR on the NA spider intake. I think fuel injectors are different too. Not sure about the thermosensor. The 2 large main wire harness connectors are different to me thinks.
The N/A intake has no tube for the cooling of the turbo. It has to be drilled and tapped and a line ran to it. The EGR is another, but I'm not sure yet what needs to be done with that. Also, the wiring for the TPS is a little different and needs to have a wire or two spliced. SubaruTex has done the transplant, and the install should be in the archives (search).
This is the first I've heard anything about the injectors being different yet, but they are both MPFI.
wait, what R U guys talking about? I thought only N/A XT's had the spyder intake, and all the turbos had the normal dual port manifold?
87.5 XT turbo had a spyder on it.. theres one sitting not too far from here waiting for a home:)
