littlemamma Posted October 24, 2016 Share Posted October 24, 2016 mine are missing (this was before o got married) and the axles are missing as well i bought a axle from a store i cannot remember but the kid told me they are all the same,there not turbo is bigger on the tranny end. are there any good aftermarket axles out there or should i godd original equipment? Link to comment Share on other sites More sharing options...
Cyfun Posted October 28, 2016 Share Posted October 28, 2016 The axle nut is a M24-1.50 castle nut. You can get them at most parts stores under Dorman part number 615-106 or 05138. As for the axles, some come with nuts, some don't. The parts store ones will likely only last a year or two, so if you do go that route, get ones with lifetime warranties such as at O'Reilly's. OEMs are great, but expensive. Many folks get OEM CV's from the junkyard and put new boots on them. Alternatively, I hear EMPI makes some good quality axles. Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2016 Share Posted October 28, 2016 (edited) have someone mail you some used ones -post in the parts wanted section? someone has a few lying around. i'm thinking all EA82, ER, EJ, EZ are the same right? nearly endless supply of axle nuts. i feel like any junkyard would give you one for pocket change? Edited October 28, 2016 by grossgary Link to comment Share on other sites More sharing options...
littlemamma Posted October 30, 2016 Author Share Posted October 30, 2016 i will try pull and save payday just wondering what size socket to bring to take axle nut off. Link to comment Share on other sites More sharing options...
wagonist Posted October 30, 2016 Share Posted October 30, 2016 M24? That seems really small, cos axle nuts here are M36 (which are huge )... I'm in a different market though. Link to comment Share on other sites More sharing options...
DaveT Posted October 31, 2016 Share Posted October 31, 2016 Wagonist is correct. I thought 24 was too small also. I just checked my wheel nut socket. It's a 36mm. It works on every Subaru I have used it on from 1976 to 2001. Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 31, 2016 Share Posted October 31, 2016 Newer subies, of the EJ flavor are 32mm Link to comment Share on other sites More sharing options...
DaveT Posted October 31, 2016 Share Posted October 31, 2016 Ah, That's a thing I did not know. I skipped most of the EJ. I can't go re check the 01 since we sold it a year or so ago. Link to comment Share on other sites More sharing options...
robm Posted October 31, 2016 Share Posted October 31, 2016 M24x1.5 is correct. That is the size of the threads, not the nut that goes on the thread. So the nut is 36 mm across the flats. Just like the wrench for a 1/4-20 UNC nut/bolt is 7/16". Link to comment Share on other sites More sharing options...
wagonist Posted October 31, 2016 Share Posted October 31, 2016 glad that I wasn't the only one that seemed the M24 was too little. So the axle thread is M24x1.5, but the axle nut (which I think is the question in the title) is 36mm. Important to make sure to read the question correctly Link to comment Share on other sites More sharing options...
robm Posted November 1, 2016 Share Posted November 1, 2016 Yeah, well he asked what size the nut was, and got the right answer. If he is looking for nuts at the local Fasteners'R'Us, that is what he needed to know. But he needed to know the size of wrench to take with him to the PnP to acquire some, and this didn't come out until 2 posts later. It is just as important to ask the right question, as it is to read it carefully. 1 Link to comment Share on other sites More sharing options...
wagonist Posted November 1, 2016 Share Posted November 1, 2016 so true Link to comment Share on other sites More sharing options...
damnsubaru Posted June 15, 2017 Share Posted June 15, 2017 my bad thanks Link to comment Share on other sites More sharing options...
czny Posted June 15, 2017 Share Posted June 15, 2017 i will try pull and save payday just wondering what size socket to bring to take axle nut off. Same size as the old air cooled VW axle nuts - 36 mm, or if you're having trouble finding a 36, 1 7/16 inch works in a pinch. Bring a long prybar to lock the hub from moving by placing it across 2 wheel studs, one top, one bottom side of studs. Link to comment Share on other sites More sharing options...
damnsubaru Posted September 7, 2017 Share Posted September 7, 2017 smaller nuts is bad genetics. Link to comment Share on other sites More sharing options...
