sethpistol1 Posted June 11, 2004 Share Posted June 11, 2004 can you put on a center lamp or head lamp on a 1982 gl wagon. if so where can i find one with the grill. Link to comment Share on other sites More sharing options...
Turbone Posted June 11, 2004 Share Posted June 11, 2004 Only if you dont have a/c. The cooler is in the way. If not, you wont need the grill, it can be cut to fit. Link to comment Share on other sites More sharing options...
sethpistol1 Posted June 11, 2004 Author Share Posted June 11, 2004 Only if you dont have a/c. The cooler is in the way. If not, you wont need the grill, it can be cut to fit. where can you get them at because i don't have a/c and also how do you put it in there. Link to comment Share on other sites More sharing options...
Turbone Posted June 11, 2004 Share Posted June 11, 2004 Here is a article on the wiring. http://usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b797565.58568597/&FileType=Article&File=ARTICLE_3f2e1983b92179.98068180.art Might do some reading here, but most of the post were from Feb. http://www.ultimatesubaru.org/forum/search.php?searchid=18052 Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2004 Share Posted June 11, 2004 I have added a centerlamp on my 83 wagon with AC. Mine is a 4 headlight frontend so I have to chop out a stock grill cuz they didnt put the centerlamp option on the quad light cars. What makes it not work? I havent operated it yet but its bolted on and ready to be powered up. Link to comment Share on other sites More sharing options...
worknwood Posted June 11, 2004 Share Posted June 11, 2004 My '82 brat came with the star emblem missing from the grill. When I found a "third eye" (center light) at pick 'n pull I took the works, grill, light, bracket, screws and wiring to the first connector. I also found an empty connector on my brat in the same place I disconnected from the doner car. It plugged right in. I also have ac, and have not tried it yet. Link to comment Share on other sites More sharing options...
Guest taprackready Posted June 11, 2004 Share Posted June 11, 2004 My 82 brat has AC and factory center light. Bill Link to comment Share on other sites More sharing options...
mcbrat Posted June 11, 2004 Share Posted June 11, 2004 here's a good diagram for doing the wiring with the DPDT switch.... Link to comment Share on other sites More sharing options...
