superooo Posted October 25, 2016 Share Posted October 25, 2016 (edited) In the middle of my swap, have a coolant line that ts off right by my water pump with a plastic valve or something in line that i cant figure where this connects, do i t it in with the little coolant line going from block to t_stat housing? Will try to get pics up, trying to take good ones as i go. Thanks for the help Edited October 25, 2016 by superooo Link to comment Share on other sites More sharing options...
ihscout54 Posted October 25, 2016 Share Posted October 25, 2016 The line you are describing with the thermo valve on it can be deleted/plugged. Best way to do it is to get rid of the metal pipe that had the barb for it. Replace it with some pipe tubing or run a new hose from the water pump to the heater core under the manifold. You can buy pieces of hose with the bend in them, if we are on the same page youll know exactly what Im talking about. The line from the thermostat housing can be attached to the barb in the block which is fairly close to being under the housing with the manifold installed. Link to comment Share on other sites More sharing options...
superooo Posted October 25, 2016 Author Share Posted October 25, 2016 Totally cleared it up for me, thanks, and the 3 lines that go to the charcoal canister on passenger side of the manifold jus go to the 3 metal canister leads on the driver side of my engine bay? Link to comment Share on other sites More sharing options...
superooo Posted October 25, 2016 Author Share Posted October 25, 2016 Actually I just realized only two of them go there one comes under the manifold via a metal crossover pipe but they all plug into the vacuum canister correct Link to comment Share on other sites More sharing options...
ihscout54 Posted October 26, 2016 Share Posted October 26, 2016 There are three lines that connect to the canisterp. Two from the engine and one from the tank. The lines going to the engine are very simple; from the purge solenoid to the control valve actuator, and from the intake manifold to the bottom of the valve on the cannister. IIRC they are different sizes so they cant be mixed up. Link to comment Share on other sites More sharing options...
superooo Posted October 26, 2016 Author Share Posted October 26, 2016 Ok, and the 4th line on the canister? Or am i supposed to change to the ea82 canister Link to comment Share on other sites More sharing options...
superooo Posted October 26, 2016 Author Share Posted October 26, 2016 Some of the pictures Link to comment Share on other sites More sharing options...
superooo Posted October 26, 2016 Author Share Posted October 26, 2016 Pretty much have the wiring figured, for a temporary fix ill be using ign and fuel pump relays to get this pig started (only i am allowed to call her that) in place of tthe bmw and Mitsubishi boxes, never wired a relay before though, and direction or advice would be immensely appreciated, i have 15 amp fuse lines for the 2 fuses, which leaves the fuseable link coming off of the ignition relay, does this connect to the factory fuseable link area or do i run it to the batt with a fuseable link in the middle? Or does it get something completely different Link to comment Share on other sites More sharing options...
superooo Posted October 26, 2016 Author Share Posted October 26, 2016 And on the relays im adding, pointers on how to tell which wires go to which on the relay connector side Link to comment Share on other sites More sharing options...
superooo Posted October 26, 2016 Author Share Posted October 26, 2016 (edited) It feels like I'm asking a lot of questions but I did the rest of it without asking any so I feel pretty good about that, and the first time she fires up I might cry, lol, just from being so proud Edited October 26, 2016 by superooo Link to comment Share on other sites More sharing options...
ihscout54 Posted October 26, 2016 Share Posted October 26, 2016 Use google to assist with the relays thats std info theres tons of diagrams out there. Either purge canister can be used pick the best looking one between the 2. The forth line (in your case) was for the bowl vent on the carb. It just needs plugged. Link to comment Share on other sites More sharing options...
