TomRhere Posted November 2, 2016 Share Posted November 2, 2016 On 11/2/2016 at 9:05 PM, Norcalbratcap said: Well i feel like an spardnubbin for wasting your time, when i started taking the motor out i told my wife to pull the ebrake...... she pulled the 4wd lever into neutral....... so the input shaft was just spinning doing nothing, about to put motor back in, thank you ihscout54 for all the suggestions and help, excuse me now I've got a hole to dig....... just kidding. D'OH!!!!!! LOL!!!!!!!!!!!!!! Hate when that happens......... 1 Link to comment Share on other sites More sharing options...
rdweninger Posted November 2, 2016 Share Posted November 2, 2016 I have not been on the forum in a few weeks. But, this is hilarious. Note to all future posters - Please divulge to us members, in your original post, of any involvement from wifes, daughters and/or girlfriends. This information will certainly expedite your repair job. 1 Link to comment Share on other sites More sharing options...
Norcalbratcap Posted November 3, 2016 Author Share Posted November 3, 2016 Yeah for sure, motors back in now, now i think i put the distributor in wrong, the shop that rebuilt the motor didn't put the disty back in so i had to, i followed my book, no.1 piston to tdc point the disty at no.1 and it the gear meshed in, got spark and fuel but no start, so gotta see whats up with that tomorrow. Link to comment Share on other sites More sharing options...
rdweninger Posted November 3, 2016 Share Posted November 3, 2016 The #1 on your disty is closest to the firewall. Make sure the plug wires are correct. 1-3-2-4 is the firing order - Counter clockwise. Link to comment Share on other sites More sharing options...
Norcalbratcap Posted November 3, 2016 Author Share Posted November 3, 2016 Let me preface this by saying i just had the engine rebuilt at a machine shop, Flipped disty thinking it might be 180 out, put finger over no.1 spark plug hole to feel compression stroke, couldn't feel it, put my compression tester on it........ it reads 0, and as ive cranked it with the plugs in it sounds just like it does with the plugs out, so methinks the camshaft might be off 180 and is opening the valves on the compression stroke, what rlse could this be? Link to comment Share on other sites More sharing options...
TomRhere Posted November 3, 2016 Share Posted November 3, 2016 It is possible that they have the valve rockers adjusted to tight, holding valve(s) open. Link to comment Share on other sites More sharing options...
Norcalbratcap Posted November 4, 2016 Author Share Posted November 4, 2016 Yep that was the issue, it's running now, kinda sounds like a diesel in the middle, not sure if it'll smooth out or not, this is the first engine I've had rebuilt so im a little freaked out by noises lol, i had it rebuilt because the front and rear seals went out and dumped most of its oil out while my wife was driving it home, and i heard a little knock from the middle which sounded like rod knock to me, so it went to a machine shop, they polished the crank new bearings seals pistons rings the whole nine, this noise I'm hearing now sounds worse than when i took it to them, so not sure whats going on now, just seems like everything that can go wrong has so far every little thing being difficult. Link to comment Share on other sites More sharing options...
Norcalbratcap Posted November 4, 2016 Author Share Posted November 4, 2016 So yeah I've got major rod knock on this "rebuilt" motor way worse than the little bit it had when i took the motor to them. Link to comment Share on other sites More sharing options...
ihscout54 Posted November 4, 2016 Share Posted November 4, 2016 Im not a fan of rebuilts, they are almost as big a roll of the dice as junk yard units. We really have no choice with EA81's, though. You need a new thread on this! You need a diagnostic ASAP. Link to comment Share on other sites More sharing options...
Norcalbratcap Posted November 4, 2016 Author Share Posted November 4, 2016 I need to take it to the shop that did the rebuild, but it's 40 miles away i don't have a car trailer, might be able to get a friend that has one to do it, im flat broke at this point so can't afford a tow truck, was going to call the shop today but just too angry. Link to comment Share on other sites More sharing options...
