(goldfish) Posted June 11, 2004 Share Posted June 11, 2004 In the papers here is a 91 loyale wagon. 121k,fwd,new clutch,5 spd,newer cv's,no rust? What are some comon things to look out for? Read about the timing belt, and something about weak heads? Anybody care to elaborate on that? It sounds like a good winter/hauler. Just want to make sure it's in good shape Thanks Link to comment Share on other sites More sharing options...
Turbone Posted June 11, 2004 Share Posted June 11, 2004 Timing belts and cooling system. Find out if either one has been serviced recently. If you want piece of mind replace the belts and flush the cooling system. Link to comment Share on other sites More sharing options...
Chris W. Posted June 12, 2004 Share Posted June 12, 2004 Along with the T-belts, check the front seals (crank and cam) and rebuild or replace the oil pump. Cheers, Chris Link to comment Share on other sites More sharing options...
