Barra Posted October 29, 2016 Share Posted October 29, 2016 Hi Folks, Looking at putting a weber carb (32/36) on my Brumby but prior to that I am looking at upgrading the exhaust to see if I can release any more power. I don't hat a catalytic converter, so any ideas on what set up I should run after the "Y" connection? I was thinking 2 inches, resonator and free-flow muffler? Cheers, Barra Link to comment Share on other sites More sharing options...
dfoyl Posted October 30, 2016 Share Posted October 30, 2016 Could go 2 1/4" rather than 2" - some have gone to 2 1/2" but I think for a Weber set up 2 1 1/4" is more than sufficient. Add a hotdog for the mid-pipe. Link to comment Share on other sites More sharing options...
Barra Posted October 30, 2016 Author Share Posted October 30, 2016 Hi dfoyl, Thanks for your thoughts, i will consider that. Happy for as many views as possible. Just want to get it right, not too big and not too small (sounds familiar?). Cheers, Barra Link to comment Share on other sites More sharing options...
BEECHBM69 Posted October 30, 2016 Share Posted October 30, 2016 I run two inch stainless with a Magnaflow muffler on all of mine. Sounds good, and it will be the last exhaust you put on the car. Dan 1 Link to comment Share on other sites More sharing options...
Norcalbratcap Posted October 31, 2016 Share Posted October 31, 2016 2" pipe then resonator then 90 degree turn upward through the bed behind the seats and a flapper to keep water out and look badass. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 31, 2016 Share Posted October 31, 2016 I kindly suggest you to use a two inches Diameter piping, and a free flow muffler, only.I've been runnin' my "BumbleBeast" since 1993 with that setup, with great results.~► http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/?do=findComment&comment=1027113Kind Regards. Link to comment Share on other sites More sharing options...
Barra Posted October 31, 2016 Author Share Posted October 31, 2016 Excellent replies Folks, Sounds like two inches is the popular opinion. Cheers, Barra Link to comment Share on other sites More sharing options...
bratman2 Posted October 31, 2016 Share Posted October 31, 2016 Another 2" with Magnaflow stainless steel muffler. Had mine for years and sounds good, not too loud! Link to comment Share on other sites More sharing options...
Barra Posted November 6, 2016 Author Share Posted November 6, 2016 Hey Folks, 2 inches of free flowing exhaust fitted, one happy chappy, bring on the Weber asap 1 Link to comment Share on other sites More sharing options...
Wobs Posted February 23, 2017 Share Posted February 23, 2017 Hi Barra, Did you get any noticeable power increase from the 2" system? Where in the system did the muffle get fitted? And do you get any droning sound from it? I'm running a bog stock ea81 with the original carb. Cheers, Wobs. Link to comment Share on other sites More sharing options...
