sirtokesalot Posted October 30, 2016 Share Posted October 30, 2016 i ran the abs check and got code 24 Abnormal ABS sensor, abnormal ABS sensor signal front left sensor. does this mean it just needs a new sensor? Link to comment Share on other sites More sharing options...
lmdew Posted October 31, 2016 Share Posted October 31, 2016 Most likely. You can check and clean the sensor. Sometimes they are full of crud. Wire brush or sotchbrite the sensor and see if it changes. Link to comment Share on other sites More sharing options...
sirtokesalot Posted October 31, 2016 Author Share Posted October 31, 2016 well i learned the reason for this sensor code. today i pulled the rotor off to inspect and clean the sensor and i found there was no tone ring at all. the previous owner told me he replaced the drivers side hub im thinking he used a non abs hub or simply forgot to put the tone ring on it. Link to comment Share on other sites More sharing options...
sirtokesalot Posted November 1, 2016 Author Share Posted November 1, 2016 abs is fixed. i installed a tone ring and put in a missing abs fuse. for future reference you can cut a tone ring in half and install the 2 halfs and have it work. Link to comment Share on other sites More sharing options...
